1. xArm-Python-SDK Installation ​
1. Introduction ​
This tutorial is written using the UFACTORY xArm 6 robotic arm, Windows system, and Python version 3.12.6 The xArm-Python-SDK is used for controlling UFACTORY robotic arms, such as xArm, Lite6, and 850.
Note: The xArm-Python-SDK only supports Python 3, and Python 3.10 or above is recommended.
2. Prerequisites ​
Before reading this tutorial, make sure you have:
  • Familiarity with operating UFACTORY robotic arms.
  • Understanding of Python 3 syntax and experience in Python programming.
  • Knowledge of managing Python virtual environments.
3. Installation ​
In a Python virtual environment, use pip to install the xarm-python-sdk with the following command:
pip install xarm-python-sdk
3.2 Install from Github Download ​
Download
git clone https://github.com/xArm-Developer/xArm-Python-SDK.git
Install via Command
After extracting, navigate to the \xArm-Python-SDK-master folder, and use the following command to install.
  • Windows
python setup.py install
  • Ubuntu Linux
python3 setup.py install
